1983 xl600r no spark
ok so installed a new moose stator in my bike because it was very difficult to kickstart the bike started 1 kick with the new stator but would stall when put into first. now the bike has very weak intermindent spark. i then replaced the cdi now i don't know what the problem is?????? need help!:moon:
:moon: Where have I heard this before ????? Hmmmm..
remove all the connections not needed to make the bike fire...
kill switches, ignition key cyl... anything you can remove.
you should be able to jump out the ignition key switch.... if you have a wiring diagram, and a good ohm meter. and the factory Honda service manual... not a Clymer.
now remove, inspect, and make sure you have good contact on all the remaining connections. don't forget to remove all the grounds to inspect them... not just wiggle them.
after that, I bet she starts.
( sounds like a pain in the a$$, don't it??? ... it is. We've all been there.... )
