2010 rmz450
Just be careful with the removal of the shock nut!
forks,
6x 30.1
20.1
4x 30.1
29.15
28.15
27.15
2x 26.15
2x 25.15
2x 24.15
23.3
rebound
5x 20.1
10.1
20.1
18.1
16.1
15.1
14.1
13.1
12.1
11.2
mid
7x 20.1
2x 19.1
2x 17.1
sleeve 2.35mm
9.2
2x 10.2
2x 11.2
shock
id 16
6x 44.25
44.2
37.15
24.2
44.3
42.3
40.3
38.3
36.3
34.3
32.3
30.3
28.3
26.3
25.3
24.3
23.3
4x 30.3
rebound
4x 40.2
27.1
40.3
38.3
36.3
34.3
32.3
30.3
28.3
take care when removing nut, looked like threads were weilded to nut on my first one, and piston ring is a rubber x ring sits perfectly in circlip groove in shock body. i have spare shafts for these if threads go same way as my first one. g-force susp
thanks for those gavin, this piston ring sounds interesting, any pics? when you say it sits in the groove where the circlip goes, are you saying this will tear it?
16mm shaft?
18 mm shaft id 16 shims. it will tear the x ring if your not carefull, i made a steel ring to fit in the groove so there is no step so to speak sorry no pictures.
the snows not bad only couple inches or so, its the frost thats pissing me off, cant get out on the bike.
tell me about it - i have some new Wp needles to try soon as track thaws out!.
so there 16mm id shims instead of 12mm ?
thats going to make that a very stiff stack, you dont know the piston port dimension do you gavin?
mark.
yes the shim id 16mm same a wp.
rear spring is 5.7 this year as 08-09 was5.6 and o6 a 5.4.
the ports are comp id of shim seat/face= 16.7mm front x 10.45mm sides x 9.6mm back side and the inner restriction ports are, 11.65mm front x 4.3mm sides x 9.3mm rear.
rebound ports are,
id of shim seat/ face= 11mm frontx 8.5mm sides x 6.6mm rear.
inner restriction ports are, 9mm front x 6.6mm sides x 5. rear.
if it doesnt make sence give me call.
cheers gav.
Edited by gavin lowes
remote key board, couple letters missing
So grinding off the peen isn't good enough on these or what??
So they're prob using a 20 to clamp on right? And taper up to a 42 or 44 to the face shim??
grinding off the peening should be good enough, mine picked up from the bottom end of the threads nearest the washer, shims an piston etc. if it was just the peening you would ony damage the nut threads. the threads seemed brittle. the second one i did was fine, maybe just had a bad one but got spare shafts made just in case.
as for clamp shims they are 23mm OD comp and 28mm OD rebound.
added info to post
