400E AP cover
I have noticed that my stock accelarator pump cover has been leaking above idle throttle settings. Iv'e wired the linkage arms together and ground the stopper down. Any suggestions?
Pull the cover and make sure the two o-rings are in place and the diaphram is seated in the groove, also check the cover closely for a crack(which I doubt).
KillerDwarf has it. You prolly lost one of the o-rings when you did the mod to the diaphram stopper.
