Steering stem swap question
I have a set of 2001 46mm kayabas from a honda cr 250 and would like to put them on my 98 rm 250. I Know the stock tripples wond work but i have the cr tripples. the problem is the head stem bearings are diferant on the top, the bottom is the same. do you think i could press the stem out of my stock rm clamps and into the cr clamp so everything would work??
or would i be better off to look on ebay for a set of 2001 rm tripples? They ran the same shoks as the honda right??
As long as the stem bottom diameter is the same and the overall length the same it will work.
