steering stem Question
take two stems with the same lower size bearing (id) is 30mm. is the stem the same where it goes through the bottom clamp? and the lower t-clamp is close to the same thickness, can you switch stems? I have a project and haven't did this before. thanks---
No. It's not always the same exact diameter inside the lower clamp. Some are close like my 07 KX250F clamps on my 2000 KX250. The old KX stem was a tight fit but I could still turn it inside the clamp. I used a center punch on the stem to expand the stem so it was press fit.
