hanging idle?
2009 S model. Has always run perfect but the idle started to hang up yesterday. When the throttle is closed it takes several seconds for the RPM to return to idle.
I've been running a Dynojet stage 1 jet kit with the 3x mod for the last 6 months and it has run perfect.
25 pilot
140 main
Fuel screw +/- 2.5 turns out
Is this likely a vacuum problem? Or??
Any suggestions appreciated.
Probably the wires or slide hanging , check the wires first.
I bet it's crap in the carb, mine does it, i take the bowl off, blow out the jet's and it's ok again, not sure where the dirt is but it always seems to work, shame it's such an ass to remove the carb.
Most likely,cold air temps or dirty pilot is causing a lean idle condition,leading to the idle hang.
probably a blocked pliot jet
make sure the throttle freeplay is adjusted correctly when you refit the carb
drain the floatbowl occasionally .
+1
Blocked pilot jet and or circut.
