Intake matching and split
In my continual quest to keep messing with my head :cheers: I decided to match the intake and put a edge on the intake split. I really hadn't thought of these things until I really got to looking at the intake manifold and some research here on TT. Come to find out the rubber manifold responds just as well to sanding with my dremel and bit as the exhaust polishing and casting mark removal on the head. I had to be careful since it is softer than the aluminum. Still tough and wore down sandpaper quickly. 220 and 400 with a couple of spots using 150. When sanding it the black wore down to a yellowish surface. The intake has its own "casting marks" with a fairly raised ridge running along the upper and lower portion of the manifold. Besides that I felt with my finger for any kind of rough snags or steps up or down of material that didn't make for a smooth transition. Have to say that I am pleased with the result since I can tell a obvious difference from start to finish.
I first started by taking away material from the head that raised or stepped above the manifold. I simply took a extra fine point Sharpie and marked the material. Removed the manifold then grind down the part that had been marked.
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/6a6eedc0420f4bc88f1bbea074d8d0de
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/110c32b483bf4ae78838e24cbba15737
Here is the finished job with the raised casting marks taken out which I did with the manifold off. With the manifold back in place I could reach with my finger and feel the lip or step down of the manifold to the head. I took out quite a bit of manifold material on the right and left. With it on the head I was able to grind and sand until there were no distinction of transition. The intake split took a good bit of filing but came out sharp.
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/3975bcf82aa142a3886f3b002ae3b0d5
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/abad36aac7864929bb8465c5a08e6a78
Just to show how much a mess it made.
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/cec1b20935dd4efa81a193c0ae1f7249
Manifold off to view other end.
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/e5f84958ba814dbca733afda3a663a3e
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/ae42c7def27046bfb4362cdf239b64d1
One more thing for show and tell. Before I started the work I have done on the head I agonized for a while over how to take the valves off without paying someone. I found a large C-clamp that I hadn't used in years, cleaned off the rust and made a notch to allow the valve and keepers to extend out of the retainer. Presto, a old neglected clamp saved me some $ :moon:
http://www.photoshop.com/accounts/b2b184eb2daa40bc94c3a5b2edb289ba/px-assets/59b4ce77b3654d8e888cb8b89ca0088f
Nice job on the C-clamp, I like it! :moon: Tip....replace the O-ring on the carb adapter, they have been known to leak air.
Nice job on the C-clamp, I like it! :cheers: Tip....replace the O-ring on the carb adapter, they have been known to leak air.
Thanks :moon:
