Issues with Linkage Bearing Install
After pressing in new bearings, then when sliding the collars in they hang up on the opposite side bearings like something isn't aligned right. This has happened on every one.
Has anyone else ran into this? :moon:
Are both the needle bearings seated in the linkage the same amount? Does it do the same thing from both sides?
Yes and Yes
If the bushing will slide into each bearing individually, try turning the pin as you push it in. Give each side a full rotation or two to get all the little pins in their places. I have had trouble as well when is packed as much grease in them as possible.
