Suspension??
If i want to reset my suspension from 160lbs to 180 lbs should i send the whole suspension in for revalving?? or should i just play around with it??
thank you, and is there any vidoes that show me how to set my suspension for my weight? or something along those lines??
Thanks agian everyone
Always a good investment toget the proper springs and valving set up for your speed. 180 is not that far off from stock settings (again depending on your speed) If you have the money do it.
Unless the valving was changed dramatically you shouldn't have to mess with that. Go to racetech.com and use the spring rate calculator. Click like you want to buy a spring for your bike and it will come up and ask you a few questions, then give you a suggested spring rate for the forks and shock. Like mentioned by Adam Bomb you are not far from stock so you might be able to get a set real cheep.
