Stock '08... what exactly will a Boyesen Quickshot, Quickshot 2 or Quickshot 3 do?
What do these things do to a KX? What is the difference between them?
Edited by the big kx
They are a cover for the accelerator pump. It just adjusts the amount of fuel delivered when twisting the throttle from closed to open.
It's not a needed device. If you have bog issues it can help if you don't want to fiddle with the carb. I you don't have bog don't worry about it
i bought my bike used, and while toolin around with it recently, i found out i had a boyessen accelerator pump cover on it. so i couldnt tell you if it is better than stock, but i still have bog. with proper jetting it still doesnt make 4-stroke bog absolete, but ive heard of them helping.
I have the QS3 on my 07. It has an adj. leak jet. After fine tuning it the low rpm hesitation was gone. But just as a side note, if my A/F fuel screw or pilot jetting was off no matter where I adj. the leak jet it had a bog. It isnt the end all of carb tuning. All other adj. must be in spec too.
