Rear brake
I have a Honda CR 250R 2001 that i havent ridden in 6 months due to having to replace the top end.
Now, the last time i rode it, my brakes were working fine but now i have fixed the top end i was raring to go for a ride only to discover that my rear brakes no longer work. the brake pedal goes down all the way with no resistance whatsoever and i can still spin the rear wheel freely.
I have replaced the fluid with no results.
So does anyone know whats wrong with it?
Any help would be appreciated.
did you bleed them right? Is there ant leakage that is visable anywear around the brake line?
If there is no external leakage and no air in the system, then the master cylinder is likely bypassing internally. But you have to be sure there is no air present in the system. If so you can buy a rebuild kit for it.
