Is anyone else going thu chain sliders every time they ride?
Is anyone else going thru chain sliders like crazy? I have a brand new ssr 110dx3. I got the beefy slider from t bolt and I still went through it in 4hrs. The chain is not to tight, it popped off twice! I ride it hard. I cant keep buying them its going to get expensive. Also what modding can i do to the chain tightener to make it more beefy, the little bolt is crappy. Anyone have any ideas?
http://i977.photobucket.com/albums/ae258/BleedHonda/100_0563.jpg
http://i977.photobucket.com/albums/ae258/BleedHonda/100_0577.jpg
http://i977.photobucket.com/albums/ae258/BleedHonda/472234445_1652566583_0.jpg
http://i977.photobucket.com/albums/ae258/BleedHonda/472235513_1652570533_0.jpg
http://i977.photobucket.com/albums/ae258/BleedHonda/472236377_1652573720_0.jpg
if you chain is to loose the remove a link. If you went through a beefy so called chain slider in 4 hours then you should contact where you bought it from and see if they can help, perhaps you got a bad one I am not sure. You will go through chain sliders, I even go through them on my rmz250 but not as fast as 4 hours.
the stock units are rubber and the units oviously that wore out
the units we sell are nylon and they are from a $2k type pit bike
we sell them every week as do others and this is the first complaint
interesting that i dont have an email with these concerns or this would have been handled promptly , feel free to contact me any time via email thecrkid@tboltusa.com
please include your full name and if poss the order #
vince
by the way cool mini , good luck with it !
tbolt I wasn't implying anything bad towards you I was just stating maybe he got a bad one or something and to contact the dealer
Disable the chain tensioner while making the chain adjustments at the swingarm, and, if you run out of adjustment, remove two links like Jeremiah recommended. From the pictures, the chain is still extremely loose, even with the chain tensioner in place.
Also, move the chain adjusters all the way forward, overlap the chain, and cut it to fit. Looking again at the pictures, you're out of adjustment.
standard chian slack guide would be 1" up and down play measured at the center of the swingarm
Hey I am sorry t bolt I was not trying to broadcast a problem with your products, I was just trying to find a solution on here before i contacted you.
I will take a link out of the chain, get the right chain slack, order another chain slider from t bolt, ride this weekend and let you guys know whats up. thank you
I took 2 links out of the chain, got 2 new chain sliders from t bolt, softened the rear shock, and ordered a 17 tooth 420 front sprocket to raise the chain a little. The only thing I am waiting on is a little warm weather, then its off to the ridge to test it out.
Heres the ol one...
I was having the same prob on my bike. I made a chain slider out of a snowmobile hifax. It only cost 5 bucks and a bout 1 hour of time plus I still have a lot of extra material left over. Just cut to size' heat with a heat gun. Mold to desired shape and counter sink all bolts. Have had it on the bike for more than 30 riding days with almost no signs of ware.
Ok guys I have been riding for 3 days in a row with not a lot of wear on the slider. To fix it I sofened up the rear suspension until it was the same stiffness as the forks. Then adjusted the chain to the correct tension. I should be getting the front 17tooth sprocket in soon, which should get it all the way off of my slider. Thanks everyone.
