Accelerator pump issue
I have a 07 250x and there is no gas being sprayed into the carb from the Accelerator pump. It is a boysen quickshot, we took the carb off and blew out the jets. I might be able to see a tiny bit off gas coming out but not enough to mention. Thanks for the help..
is the diaphram torn or have a hole in it? take out the diaphram, stretch the spring out a little bit.. i also went to the length of shaving about two thousandths of an inch off the diaphram rivet and made sure the squirt was timed right..
Make sure all the little holes in the AP cover are unrestricted by dirt/debris--blow through with carb cleaner and compressed air. Also check the passages in the body of the carb that lead to the AP nozzle. Not too likely any problem with the diaphram, but I did have one become sortof curled-up, so I replaced it. My AP became non-functional for reasons still undetermined, but the O-ring modification to the link-lever corrected the problem and made it work better than ever.
