help! White smoke!!
hey guys,
i recently bought an '05 crf250r and its been great to me. I've only put maybe 5-6 hours on it since I've had it.
however, I just started it today, for the 1st time in about a week, and in no more than 20 seconds, honestly, quite a bit of white smoke was coming from the where the muffler bolts on to the exhaust pipe. The exhaust is still blowing good out the muffler, but the smoke isn't noticeable out of the back.
also, a bit of white smoke is coming from what I believe is the decompression valve? (little hole on the right side of the head)
Could running it too rich cause these areas to smoke? If so, Would turning the fuel screw underneath the carb clockwise help me?
Thanks for any info.
White smoke from the exhaust after everything has warmed up is probably steam/coolant. Maybe from a blown head gasket or something else... Loosing coolant? If you open the cap up when it's cold and start it do you see any bubbles? Any milky oil?
What "hole" on the right side of the head do you mean?
check your coolant. He means the hole on the right side of the head. Most likely time for a rebuild if the smoking does not stop.
coolant level is good. bike runs pretty good too, no significant loss of power that i can tell.
it really smells like something is melting between the muffler and exhaust pipe connection, so i pulled it all off and checked to see if everything was ok there and didnt see any sign of it.
time for a rebuild huh? I was really hoping I wasnt going to get that response.
The smoke is either coolant or oil. If it's coolant smoke, eventaully you'll have to add some to the radiator on a regular basis. If it's engine oil smoke, it could be overfilled, rings, valve guides and or vavle guide seals. Also check the "appendix hose" (with a cap on the end of it)that hangs down from the vent hose that runs from the valve cover to the air cleaner box. Over time it will fill up with oil (normal) and has to be drained. If it's full, then raw oil will migrate to the air cleaner. Don't know what your problem is, but it sounds like valve guides and or seals. If the seals are worn and the bike sets, a small amount of oil will ease past the seals and into the cumbustion chamber. Then when you start it, it will burn the small amout of oil and smoke for a few seconds and make smoke. In the meantime, check you oil very very often. You don't won't to seize an engine on the face of a jump.
If it's engine coolant, it will have kind of a sweet smell to it.
If it's engine oil, it won't smell like wood or paper or plastic burning, it will have a smooth smell to it.
i went ahead and leaned out the fuel screw about a full turn. and there it was, no more smoke!! i guess it was just runnning to rich.
man i love an easy fix!!!
but it sure did have me scared for a few days
you said smoke was coming out of the little hole in the head? (spark plug drain hole in case moisture in there) check your plug and make sure it isnt loose.. also your gas may have water in it
my plug was really loose, It amazes me that the bike was even running. i pulled the plug to check for carbon build up, and realized it. tightening it back down solved the issue there too. Thanks for looking out though, you're 100% right.
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
