90cc head
Can i put i 90cc head on a 110 cylinder?
Maybe, if all the following are in spec and nothing is too close to touch or too high compression will blow the bottom end out. Check you specs!!!
Bolt pattern
Gasket pattern
Bolt length
Bolt size
valve clearance
piston height
compression increase
bolt torque
-BIG DAN:thumbsup:
