Help front forks!
ok, so i changed my fork oil to 10w. i did this because i weigh around 230ish and i want my suspension to be a bit stiffer. After the change in oil and seals, i feel the front suspension stiffer. I took off 3 clicks off the compression. Do i need to take off the rebound? any help is appreciated.
thanks
Having springs still in the front end that are to soft will let the front end ride low already.
You will have to take out some rebound or the front will never recover from the bumps.
Heavier oil is just like adding comp and rebound to the clickers.
You should really add springs to hold the front end up and get a correct revalve.
