Honda Clutch Switch
Safety feature....intended to prevent you from activating the starter with it in gear, without the clutch pulled in. If you did this, it would lurch forward and things could get exciting!
Found on virtually everything out there, and not at all unique to your ATV.
Never considered that, so I never thought it out.....
If your clutch pull is hard, try replacing the cable with a new one that is well lubed.
