What pipe?
Finally saved enough money to put a new pipe on my DRZ, I leaning towards a yoshimura RS2 carbon fiber or a stainless steel scorpian. What I'm wanting to know is what the performance difference is betwee the two pipes as in HP gain?
Thanks very much.
They are the same the difference is just the muffler sleeve .
The best pipe for hp + money is the Ssw/MRD !
Fwiw, I'd never put a carbon pipe on a dual sport bike. Simply too fragile and expensive to repair if it gets munched. I know that doesn't answer your question, but it simplifies the choice - at least for me.
I would say go for the MRD best pipe out there! And even cheaper than the rs2..
If it's just a slipon , no gain at all...
A full exhausts without doing anything to jetting (jet kit) or a better carb is also almost waste of money.
Your choice of slipon with an FMF power bomb header, I did the Leo Vinci, I like it...
get what fits your needs. if you want to gain awsome HP in the long run,or simply want the best theres only two-yoshimura Ti, or mrd/ssw
if you want good power and sound with the bling factor get everything else
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
