Engine casing
Does a DRZ 400 2001 kick start only model have the same size left hand side engine casing as the more recent s and sm?
Craig
There might be a diiference becuase of the E start?
The engine cases (crank case) should be the same... BUT... if you are talking about left cover, that holds the stator... those are different. The S/SM/E has a bigger stator and mag/flywheel... and has the starter parts in it.
Cheers for the reply.
