Bike for my son ??
My son is 12 yrs old, 4'9" and weighs about 90-95lbs. He is coming off a PW80, which while small for him, was good for him to learn on this past year. He has shown some skill and was rdy to move-up to a bigger bike in short order. Problem is, from what I've read, is that he's currently a tweener between the 65's and 85's. He appears to be on the hvy side and maybe a bit tall for the 65's. But, he appears to be a bit short for an 85 (even the shorter KX). Really short for an 85 considering he'd be learning to use a clutch as well. I could go with a CRF80, which would be a good fit size-wise but I'm afraid he'd be pushing its limits in no time and then seeking a higher performing 2-stroke. Any suggestions appreciated - Thanks !
noooooooo! The klx 140 weighs over 200lbs! I would say weight a couple more months. My brother is the same size a and weight and he is on a ttr90. He will move on when he grows a little more.
so does the ttr 125, or the crf150f, but those have crappy drum brakes
the next step up would be a kx100 imo, or a ktm 105
Kawasaki
Kx100
Seat height 34.3 in
Curb weight 156.5 lbs.
Kx85
Seat height 33.1 in.
Curb weight 152.1 lbs.
Klx140 (small wheel)
Seat height 30.7 in.
Curb weight 205.0 lbs.
Klx140L(Big wheel)
Seat height 31.5 in.
Curb weight 209.4 lbs.
Honda
Crf100f
Curb Weight 174 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
Seat Height 30.9 inches
Crf150f
236 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
Seat height 32.5 inches
Crf80f
Weight 163 pounds
Seat height 28.9 inches
Yamaha
Yz85
Wet Weight 156 lb
Seat Height 34.0 in
tt-r125e
Wet Weight 198 lb
Seat Height 30.5 in
tt-r 125le
Wet Weight 198 lb
Seat Height 31.7 in
KTM
85sx
Weight (no fuel) approx. 68 kg (129.94 lbs)
Seat height 845 mm (33.27")
105sx
Weight (no fuel) approx. 68 kg (149.91 lbs)
Seat height 900 mm (35.43")
105xc
Weight (no fuel) approx. 68 kg (149.9 lbs)
Suzuki
rm85
Seat Height 850 mm (33.5 in)
Curb Weight 73 kg (161 lbs)
rm85l
Seat Height 875mm (34.4 in.)
Dry Weight 69 kg (152 lbs.)
drz125
Seat Height 775 mm (30.5 in)
Curb Weight 88 kg (194 lbs)
drz125l
Curb Weight 89 kg (196 lbs)
Seat Height 805 mm (31.7 in)
I would check out crf 100 or xr 100, sure they have drum breaks and no e start, but we all managed to grow up without these things...
And the ktm 100 and 105 have an incredibly tall seat! He couldn't touch for a long time.....................
and they are easier to ride than an 85, basically the same size as an 85, but with more bottom end, smoother power
no, not the same size!
85sx
105xc
But I don't think it matters right now because my brother, who is 4'9" and about 90 ponds cant even touch on my 02 yz85. Its still too big for him if he tries to stop.
