QTM Brembo TT Store?
Hi does anyone know if I can buy the QTM/Brembo radial caliper kit from the TT store?
I looked and looked, but, couldn't find it. Just wanted to make sure I'm not missing it.
Many thanks. :ride:
Edited by Harvey600
Well, after 38 views and no replies, I did the thing I should've done in the first place. :ride: I contacted the TT store. (well der!)
To cut a long story short Matt is doing a special order for me. So yest the TT store can get the QTM Brembo brake kit.
This topic is now closed to further replies.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
