SM Fork guards
Im after a pair of brand new Fork guards for my DRZ400SM. Which fork guards (eg ufo or acerbis) will fit?
Will rmz450 guards fit or rm250? etc etc
Im taking the speedo and cable and all the mountings off my bike so those dont need to fit onto the guards. I just need a set of fork guards that line up to the bolt holes and do the job of protecting the forks :ride:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
