Fixing boogered up cases
I bought a '97 CR250R in May from someone who had just rebuilt the engine. The bike has both burnt and leaked crankcase oil like a pig ever since I got it. I just got around to splitting the cases to find out what the problem was, and it became obvious that the previous owner had pried the cases apart with screwdrivers and a hammer (notice in the pictures I used a Tusk crankcase splitter). Some of the screwdriver gouges in the sealing surfaces are pretty severe.
I'm looking for advice on how to repair this. The previous owner apparently tried to help the Honda gasket out with lots of silicone sealant, but that didn't work. What about JB Weld? Machine work and an extra gasket? Welding?
I enjoy riding the bike, and appreciate any information from someone who has fixed this before!
Maybe someone can tell me how to post pictures.
Suffice it to say the mating surfaces of the cases have deep screwdriver gouges. They aren't going to seal without some repairs.
There are people that can weld magnesium (I think those are mag), then just machine the surfaces; probably someone local to you. No biggie. Belzona Molecular makes an epoxy product that will work too, but it's rather expensive (but probably less than replacing a case if it ever came to that).
Fwiw, link pics from
If I was you I would do it right and buy 2 new cases.
Isn't that like $600... ? :ride:
I'd think it would be cheaper to fix them or get an engine off of ebay and pray the cases aren't equally buggered.
Yeah, I don't think new cases are going to be my first option because of the cost. And I really think this should be fixable--I just haven't done it before. Also, are you sure the cases are magnesium? I'm thinking they are aluminum.
There's a test for it; the shop that you take it to should do it before welding. If they use an aluminum stick on a mag case or vice-versa, the weld will corrode (turn to dust) and fail. (one test: aluminum is attacked by caustic soda, magnesium is not - you can do this at home if you have the chemical and a small scraping from the case; here's a link: ) In either case, whether they're mag or aluminum, a local shop with a TIG and a skilled welder should be able to fix those up for you at a reasonable price.
I like JB-Weld for lots of things, not so much where it's in contact with petroleum products for a long time. Surface prep is key if you're going to give it a go.
I've had cast aluminum tig welded before, works fine. If your handy with a file you could most likely get it 90% there, then flat sand it a ground plate or granite slab.
Devcon (I think that's right) is an industrial type metal epoxy similar to JB Weld that would be reasonable to use, should be able to finish the same way as weld. I don't think pre-mix won't penetrate the epoxy, and provided its applied to a clean surface, it shouldn't get between the case and epoxy. Keep in mind porters have used expoxy inside cylinders & cyclinder heads for years with great success.
Devcon =
Do a google search for: cyclinder head epoxy
My rod failed and fragged my cases out pretty good, I brought them to a local genius fabricator/machinist, he filled them in and ground them down.
They look great and it was $100, and I had some big chunks gone. I think the key is not much heat, these things warp like crazy if they get hot.
Good luck.
Clean them up real well and use jb weld. Let it set up 24 hours the see if you need to add more. File it down with a large flat file then use a large sheet of sandpaper to finish. The trick is to go easy with the file. When you are ready to put it together with a new gasket, use Yamabond or Hondabond sealer on the whole thing and you should be good to go. If you have to take it apart in the future, use some heat from a propane torch to loosen up the sealer. I have used this around the crank area of 2 strokes and never have had a problem. Don't you love HACK mechanics!
I've fixed more things on this bike than I care to mention:smirk:. The powervalve wasn't functional when I got the bike. Also, I took the head off and found it had been pulverized from the previous blowup, and there were still pieces of bearing embedded in the combustion chamber!
I don't hold a grudge though--it was my fault for not being more careful with the purchase. Besides, it's been fun to fix the thing and get up to speed on 2-stroke repair.
For that kind of gouge, JB weld is the ticket.
A piece of glass with emory cloth is a great way to do the final sanding. Put the glass on a table, tape the cloth down to it, and slide the case across it
Well, here's my apology to 97 Polaris. After cleaning up the cases this afternoon, I've found that the right side has a crack running from the bottom of the main bearing journal all the way to the bottom of the case. That must be why when I pressed out the crank, the bearing stayed on the crank instead of inside the case.
Looks like I will be buying a new (or good used) right side case at the least. Fortunately, the right side is the one that has been chewed up the most. Dang hillbilly mechanics!
Anyone got a good right side case for a '97 cr250r?
Expoxy the low spots and file them to match the gasket surface. The gasket will take up some small imperfections so don't worry if it's not perfect.
Honda has a good right side case, it will cost you $150-180, though.
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
