Front number plate.
I put one on my 06, only thing I needed to do was put 08 triple clamps on it too. It turned much better with the 22mm offset clamps.
To answer your question, no, 08 front number plate will not bolt up to the 06 stock clamps.
ordered a 2008 front number plate this morning, it was 24.00$ ill get back to you guys on how it worked out
I did the same thing.
Only pic ive got right now but 08 number plate on 06 zip tied. you can hardly see the zip ties.
I didn't like the 22mm offset clamps on my '08 450 so I put a set of '07 (24mm) clamps on it (much better). I wanted to run my '08 numberplate so I drilled and tapped the bottom clamp and was going to use lower fork guard collared allen bolts. Problem is, I snapped the tap off on the second hole. :ride:
Was thinking about making a bracket from fairly thin steel for the top but, of course, didn't get that far. Fortunately, I had planned on getting Applied clamps if I liked the new offset.
sorry for the late reply. here is his on the backside. the reason i did the 08 09 number plate was because i put the damper on.
yes i believe i was going to buy your dampener, but becasue of the price of shipping i didnt. im just putting the 08 on because of looks
