xr-200 shock fit a crf-230?
I have one here and i beleive they are about 3" shorter than the 150f shock.you could have it rebuilt with a new longer shaft.Not sure what a local to you shop would charge but I can get shafts for about $70 and charge $50 for the rebuild.If you can get it cheap enough it might be worth it.I would count on a rebuild at the minimum for any shock bought unseen.
I am running an xr200 spring on a cr 80 shock,I turned a spacer for the spring and mounted it up.I haven't run it on the track yet due to the white stuff on the ground.
good luck
Farmerjd,
don't run an xr200 or a xr250 shock. Just trust me on that one. If you need a reason, just remember those are old school shocks. You already have that. If you want to upgrade, those shocks wouldn't be the right direction.
ok, thanks
