Bad Fork Bushings?
Iam kind of new to this scene so please excuse my negligence....
i recently changed my front springs (BBR HD) and bushings (stock replacement) as well as the fork collars (stock replacement) on my 04crf50 once i had everything back together they seemed to be working great, nice and stiff with no play what so ever.
Now, (only 5 months later) they have more play than ever, i took them apart just to make sure the problem was not caused by foreign material scraping the nylon away. it was also still packed with fresh grease (some of it was still red).
Iam afraid if i just go out and get new bushings the same process is going to happen over and over again.
Can someone tell me what i need to do/did wrong?...thanks in advance
You said you swapped with stock replacement bushings that's why ... You need to run some delrin bushings like these.
NOT SAYING YOU HAVE TO BUY THESE OR THESE ARE THE BEST JUST SHOWING YOU WHAT YOU WANNA RUN . Like a 100 times better than stock and don't compare. These make the front
end feel solid.
Another question are you running chromoly fork legs??? While doing bushings do the legs also . You can get complete kits like this with everything in one Extender Kit
Thanks for the link but it seemed that the original stock bushings did pretty good for me (for now) i figured since iam changing from stock to stock i would get the same performance as the ones that came with the bike but thats not the case...
is honda just making cheap replacement parts?
if thats the case im going to order the red baron forks but ONLY if need be.....
keep in mind im in canada eh, so parts dont come so easy but RB seems to deal through parts canada so it looks like i am in luck in this case
okay, i ordered the new delrin bushings, should have them next week \m/,
It's not that Honda is making cheap parts its that they make it for 5-8 yr old kids under 80 lbs those stock fork legs will eventually bend also they are thin metal that's why I suggested the chromoly legs. Here's a site in Canada I know of not sure about any other sites
thanks alot but i already ordered the bushings through parts canada. as for the forks themselves, ill be waiting til next fall as i am a cheap bastard and would like to upgrade to 88ccs with 4 sped tranny first
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
