Winter Project '01 CR2fiddy
Tuesday Jan 26th i was bored and started to wash my bike, manualy. then started takin parts off for cleanin, then after about 3 hours there were no more parts to take off and wash. so now its officially a rebuild. strepped motor, swingarm, various parts. ALL manually, no machines, sandblasters of any tools... yet to touch frame, or polish any parts intr morlty just strippin and a lil sandin so far
good luck with it. and did your swingarm have a coating of some sort on it before you started sanding away? i have a 01 twofiddy myself, and a few years ago i went to polishing everything. which involved me sanding off a tough clear coat of sorts on my swingarm before the polish would do its magic. took a while to get it all off there.
just curious if someone did this before me, or it was factory.
On the swingarm it had a powdercoated black, but no special coating or no clear coat...
My 01' looks the same, just drove out the swing arm bearings what a nightmare they hadn't been greased sense 01'.. Good luck on the build.
HOLY SHIT buddy! I Know what a game, at first i bashed in with a i believe it wa 19mm socket and extension, no go, so i started usin my brain a lil from what i learn in auto serive & repair at college. 19mm on outside of the bearing, 1-1/4 socket on the inside NOT touchin the bearing but layin on the aluminum shoulder or whatever its called. and then just screwin in the vice... easy as pie... incredible:thumbsup:
here's today, about 3 hours on rear shock disassembly, cleaning, stripping. ALL BY HAND again no machines used, no sander, no sandblasts, no wire wheel.. i take great pride in hands on hard work on my bike... i dont let other pople work on it.. lol
comment welcomed...
are you gonna repaint the spring? they're steel and will probably look kinda lousy once it starts rusting
Yes i most definitly will paint the spring, the purpose of strippin was to repaint everyhint got new and something different, i will be matchin the front & rear caliper and the rear sus spring all the same colour, thinkin of a nice like cherry dark red, something that stands out but not tooo bright... thanks
good old PB Blaster! smells like shit,works like crazy! lmao. looking good.
make sure to post some pics of the cherry red pieces. love to see how it turns out. might even do it to mine.
keep the pics comin! cant wait to see what it looks like after lol :ride:
Keen eye Boneyard! Thanks peeps keep em comin , keeps me motivated wanting me to do more... PB, Tim Hortons, Gatorade and Redbull keeps me going in there! no time tonight to work on it lots of college homework and busy but ill get back to her soon... some people been tellin me to get rid of it and save my money, put my money in a better place while i'm in college, Screw the money i can dig a whole and get out once im outta college and makin money..
wow, i've been superly busy with college, work and at home, but i got more done here the latest... finaly got my parts in for swingarm. hopefully will have it, the frame, and the engine all done and together...
I do love little packages with Honda emblems on them...:ride:
how do you polish the swingarm and frame?
i just stripped the paint off with gel, wire brushed it, i did it this way, might be better ay but... I sanded rough stuff with 220 then 350 all in same direction i went in legnth direction. then add buff compound and buff to satisfaction it on bench grinder, its the only powertool i really used to far... oh and yeah JRS turn, me too. Support your local shop, they dont get so much of a payout on aftermarket
Like i said, no blaster or real power tools, just got bench grinder with buff wheel for finish.. stripping frame completly i just decided and started tonight
Lookin' good man! :ride:
looks good. how long does the polish look good for before you have to re buff?
I love these rebuild threads!
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
