400EX rebuild
Honda
Hey every1 !
This is my first thread so I thought I would start by asking about my 400ex being rebuilt.
So far I have:
-punched in a 440,
-12.5:1 wiseco M series dome,
-stage 2 hotcam,
-port and polish,
-3 angle seat cut,
-new honda valves (i know... should have gone aftermarket),
-new honda valve guides,
-kibblewhite light weight HD valve spring kit,
-dynojet kit,
-HD clutch,
-k&N filter,
-Pro-Curcuit T-4 slip on,
-down two teeth in the front sprocket,
-durablue eleminator axle,
-will run vp high octane fuel
I would still like to:
-replace timing chain
-aftermarket header (maybe replace the T-4 with a different brand full system)
I think that's all I can do unless anyone has any suggestions to get a little more juice? What else can I do?
My thought is that the money you would pump into the 400, would be better spent on a new 450!
There is really no advantage to the KW springs with your set-up. The money would be better spent on a good used FCR carb. Definetly replace that stock cam chain with one from a 02-08 CRF450. The VP fuel will not be necessary either, Get some good fresh 92-93 pump. Have fun!
