ok, i have a 09 kx250f, and i ordered a pivot works fork rebuild kit, it comes with o rings, bushings, and the seals/wipers. for the shcok i just ordered the MSR shock seal and i guess the seals have bushings on the inside. but as i looked i seen on the shcok piston theres a ring, but it looks like a bushing. the parts list calls it a pistion ring. i didnt order one of these. do i have to replace it? i have 72.2 hours on my bike. any help is greatly appriciated.:ride::lol:
If you're replacing the rest of the guts, I'd recommend it. It's the working seal for the piston and it does wear affecting your dampening.
Really sorry for the hijack, but does anyone have the .pdf for the '09?
ok well it seems fine, jsut got back from teh dealer, and i got my shoc seal kit, and the mechanic said dont replace it unless its tore up or in bad shape.
The piston band is super tight on these shocks. I have piston band load o rings from a 46MM KYB that take some of the excess pressure off the band, gets it down to a good size. Some suspension guys have reported the bands being burned they are so tight.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
