'97 cr2504 minimum clutch stack height
I've searched the forum but can't find this. No, I don't have the service manual.
Does anyone know what the number is?
Thanks,
Lynn
Not sure what you are referring to with the clutch stack height.
Clutch Disk Service Limit: 2.85mm or (0.112 in)
Clutch Plate Service Limit: 0.20 MM or (0.008 in)
I do have the manual so if you need anymore info let me know.
Thanks for the info! The stack height is the thickness of all the plates stacked together. I believe there should be a number in the service manual. Mine measures at 34.50 mm. I'll measure the plates individually and reference the numbers you gave me. Thanks again,
Lynn
