Öhlins Fork and shock
I have a fork with clamps and a shock from Öhlins on a RMZ 450 from 2007. Will this setup fit on a newer bike? The RMZ 450 from 2008 to 2010?
All parts should fit. You will have to use the number plate and fender from the older bike, unless the fork diameter is the same as the stock ones then you can use stock clamps.
I have Marzocchi 50mm works forks with triple clamps from my 05/07 bike and they fit on my 08 no problem but as Aaron wrote you do have to run an older style fender and number board, i went for a vented cycra one, the set up also fits on my RM250AF, you can see pic's of it in my garage.
