LTZ carb vacuum hose routing problem
Hi, I recently bought an 03 that has not run in a long while and just cranks over and back fires. the vacuum lines are off as well as the vent hose. i have the manual but it does not show where the upwards pointing barb fitting connects. i have cleaned the carb jets too. Do these hoses need to be connected? Thanks!
its just hose,...............put it on . were does it drain to ? ?? ...... it drains to the ground.
they really don't get used unless the machine tips over
the ltz/kfx/drz have a hose coming off the cab and hooks to the petcock on the gas tank. it puts pressure on it and pumps the gas into the carb when the petcock is on the on or res position. if u turn it to the pri position"knob thing should be pointing side to side then" it will run with out any problems with out the hose being hooked up.
i actauly dont know why they put that on those bikes.
thanks guys, It runs great now.
  • Similar Content
    • By Christo6060
      Should I buy this bike my uncle just sold one and said in good condition they’re worth from $600 to $1200 and if I could get it for $300 it would be a good deal.
    • By Michael570
      Can anyone link me some aftermarket shocks and such. Im looking for racing shocks and I can't find any. Also I'm looking for a frame cradle for my bike. It's a 2017 but I don't think that matters.
    • By Markl5557
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By SendIt
      Was wondering if a newer model exhaust can fit on my 05 RMZ-250. My stock exhaust is rusted out and I prefer the look of the new ones and have seen great reviews on some, as I also want more weight savings. I have been unable to find out if a newer model can fit on my bike, was wondering if anyone could help me out.
