2006 YZ250 Spark plug gap???
I bought my bike used and did not get a manual with it so I was not sure on the gap. It came with a br8eg and appears from reading here most are running the BR8ES with no performance difference----True?? or just stick with the BR8EG. Thanks---
I am fairly sure the gap is 0.8mm, but should come pre set from NGK. And yeah that standard ignition is designed to be used with a BR8EG, but most get away with a BR8ES.
Or you could save money and get the B8ES, I believe the R is for resistor and our bikes dont need them
I've been using B7ES for years in both my 2003 YZ250 and 2001 YZ125 and rarely foul a plug. The 7's are one step hotter and prevent cold start fouling.
Larry:thumbsup:
Are you guys sure on the .8MM spark plug gap? The one I took out only has .5MM gap as well as the new plug is .5MM. I wish they had the service manual on line so I could check it. Correct gap please??????
