Odd jetting issue....thoughts
So as of today my idle seems kind of high. Currently I have my air control screw at 1 turn out to richen it up a bit and regardless of where I adjust the idle screw it stays the same.
165 main
35 pilot
#2 clip N2ZJ
If the idle stays high does that indicate lean conditions or rich?
What altitude are you riding at? Unless you are riding at a high altitude, those settings do seem lean for the winter/cold temps.
What you describe is a lean condition so put in a 38 and it will strat and have better bottom end.
also, don't some of the KTM 2 strokes have a stock AS setting of 1 turn?
throttle cable free, not hung up at the carb or anywhere else?
pilot clear?
idle screw not broken?
pilot clear?
Maybe . Yes . Yes . No .........
