Why does my rmz450 have to much compression?
what would cause so much compression that i cant kick start my bike? i just changed timing chain and adjusted timing it ran fine and started right up after i set timing. but now a week later and i have hella compression. its so much that sometimes i cant hardly move the kick starter while i am on the stand and i weigh 200lbs. Please help
Sounds like your automatic decompression mechanism is stuck.
where is the Automatic decrompression mechanism located on a 05 rmz 450?
On the end of the exhaust cam.
that is excactly what it was thanks. the bolt was loose not allowing it to decompress. I tightened the bolt and it fired right up. Thanks again
have you got any steps for me to follow, i have the same problem,
have been looking in my manual but really cant find what i need to tighen?
