Changing the rod -XR650R
Whats up guys?
I used the forum search but couldn't find my answer.
So, Whats the trick to change the rod in the XR650R crankshaft? a machine shop with a press?
Since there is no OEM rod what do you recomend Falicon or Carrillo?
falicon, there more abundant than carrillos.
I do my own rods,mainly older 2-strokes,But...these big boys are tight!I can't do them,i have a bike shop with a BIG press do them.
Another note..alignment is very criticle.Don't just give it to someone with a big press.
Contact he did mine on an XR200 for about 150$
Nice link...someone that specializies in cranks.
Edited by scalejockey
Did that include a new conrod?
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
