Kill Switch stopped working. Any ideas
About 8 months ago I installed a Baja Designs kit on my 2006 XR650R. Everything worked great for 6 months and then the kill switch stopped working. They sent me out a new controller unit but it also did not work. I have checked all the obvious connections and have not been able to find the issue. Everything else works but the kill switch.
Any ideas on what else to check would be greatly appreciated!
well check where its plugged into the wires and if there good there i would trace back and follow them and check for another connection. how far did you follow those wires back????
The kill switch simply grounds the ignition. Check the ground and do as D10 says as well- def not rocket surgery.
