Yamaha Has anyone done the TT-R 225 mods?
I bought a used 2004 TTR 225 and I am doing the air box, jets and exhaust mods I have read about in earlier threads. Anyone else already done it? What were the results? Tired of push starting and starting fluid. Is higher octane gas going to help run better?
If you're having cold start problems, try the following:
when you're done riding, turn off your fuel petcock and allow the bike to idle until it runs outta gas.
Seriously.
It should start MUCH easier next time you go to ride it.
Thanks for the input, I will definetly try that next time. The xt is the same motor. I am replacing the 130 jet to a 132.5 also, since I have opened up the air intake and exhaust.
You should also shim your needle with one washer and use a 40 or 42.5 Pilot.
