valve and carb
what is the average cost to get the valves adjusted and to get the carb cleaned and adjusted
i would reccomend doing it yourself. its really easy to do with help from us on here and the owners/service manual. dont be afraid! if you were to take it to a shop im guessing it would be 2-3 hours of labor at probably 80 or 90 bucks an hour
i dont know how to adjust the valves and i realy dont want to mess it up and i there is somthing realy messed with my carb because me and my dad have tried changing the jets twice and it still doesnt like to idle. And it burned the last plug i put in it after about 5 hours of riding. Also it was imposible to kick over and even the electric start wouldnt turn it over but i took out the spark plug and now the compression is where it should be.
go to your local dealer and see if you can work with them and they will teach u how i did that with my local dealer and it only cost $40
or break it down into specific jobs instead of all at once.
Checking valves is one item - and easy. In the event that your valves are so tight that your kick and e-start don't work - you might need a whole valve job versus an adjustment.
Cleaning the carb - super easy. Just requires labor - disconnecting the sub frame, shock, front carb boot, throttle cable, hot start cable.
I recommend you just check your valves to see if the clearance is in spec. If they are in spec then no adjustment is needed. It is painfully easy to check your valves...simply remove your fuel tank, remove the spark plug wire, then remove the valve cover. There are several threads here on Thumper talk in both the 250X and 250R sections.
If the problem is with your bike not idling then I would look towards your pilot jet in your carb or your fuel screw adjustment. Before you mess with the carburator make sure your Hot start lever or cable is not held open.
Figure out each problem seperately and it is much more simple.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
