should I buy 2001 kx 250?
Hey guys, it has after-market exhaust fmf sst head pipe and fmf power core 2 silencer. He's asking $1600 what do you guys think. I know these bikes have had problems with the lower shock bearing and rear wheel bearings, but do you guys thinks its a fair price.
Any other frequent problems with these 99-02 kx 250's?
Average blue book value for this bike is $1547.50. The low end is $1230. Hope this helps.
ok thanks, do you think I may be too small for a 250? I"m only '5"5 and 150lbs. I have not rode in awhile. should I get a 125 instead. I"m going to do both trails and track
Size is relative; a skilled rider can ride any bike. I'm 5'6" and ride a 250 with no problem, except for the dead engine start at a hare scramble. A small step stool fixes that. The ability to dab is nice but not absolutely essential. We all learn to adapt to our environments. If you have the cash you can always lower the bike. Happy trails.
Can't help you on your 01 but, I can tell you I've gone back to smoking on a 04-KX-250 and absolutely LOVING IT!!!
I know the smokers in my area are really priced high but, remember what he's asking isn't what he'll get. :ride:
Edited by MXOldtimer
So it sounds like I'm gonna be on my tip toes trying to start this kx250. I offered him 1400 cash. He said he would consider it. If he accepts it, is this a fair price?
How much lighter are the 125's, same year?
only a few pounds, the 250 will be easier to ride. also you can lower the suspension an inch or so.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
