Tweqs custom graphics
Have you guys heard of There you can design your own graphics for your drz. They will print what you design and ship it for around 180 bucks. I recently started to work on my own desgin but I'm wondering; about the quality of these graphics; after all they are expensive. So my question is; do any of you have your design from tweqs on your bike? Is the print quality of your design good? Also if you can please post pictures.
i just got mine today from Tweqs, i custom made shrouds and number panels. The quality is very good but you may want to ask for color swatches because i have the white drz and their white template didnt match so i had to cut out the shapes. ill post pictures soon but overall i do like what they do. Also once you order they look over it and e mail you what itll look like and give you a chance to correct anything. also it took about a week and a half from when i ordered to receive it
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
