visual ID'ing sss forks?
hey all
I may be going to look at 06 125. I reckon that about 1/2 the dirtbikes I see advertised on CL are incorrect year than advertised(01 advertised as an 05, see it all the time), so I wanna make sure it is an 06. I intend to check the VIN( 10th digit should be 6, correct?) and I also want to know I am getting the 06 forks. Are they not a larger diameter upper tube where they fit into the top triple? And do they have a recessed cap?
TIA
j
'05 forks appear externally identical to '06 and later sss forks. You only have to worry about the '05s, as '04 and earlier are clearly different.
