DR350 Jetting Suggestions
I have a 440 installed on my 1991 350s kick start model, stock exhaust with an 39mm mx fcr elevation sea level to 800 ft, 46 pilot and 150 main ,had to do a bit of port enlargement to accomodate the fcr, you didnt say which carb you have but from memory if its a standard bst most guys i know are using a main from 142 - 148, but cant comment on pilot sizes for this type of carb, also as you have a newer electric start model the largest fcr that will fit is a 37mm Dunno if that will help but hope it does
Thanks for the input. I've got a flat slide carb, don't know what model. I really don't know much about the bike. I got it recently and haven't pulled it apart yet. I'll pull it in the shop soon and tear it down.
