suspension/springs
I'm 6' 175 lb i ride hare scrambles & enduros in the north east rocky rooty slippery in Pa & Ny and long sandy whoops in NJ i do best in the fast stuff the slow teck riding is more difficult for me i talked to factory connection about my springs they suggested .43 in the front and 5.3 in the rear and run 105 (4 3/16) sag ,race tecks chart says 5.12 rear spring (hope i didn't go to stiff) the bike always felt like the rear was to low and forks would not stay down in the turns i had to set the clicks very stiff...is anyone else using this combo?
I've been running 44 in the front and a 52 in the rear. i weigh 180 (225 in full gear) Forks and shock have been revalved too. The bike works well in the tight stuff but i also soften up my suspention quite a bit and lowerd my forks approx 1/4" in the clamps to make it turn better a slower speeds.
Recheck your weigh in full gear ready to ride and make sure your sag is adjusted accordingly. It can be suprising how much weight you add.
Stkman62...
I just went throught the same thing as you about a month ago..and we're both the same weight so I think I can give you some guidance.
You're going to get various answers from the different suspension experts...just get used to that. I'm about 173 lbs (198lb in gear)...Race Tech had me at a 0.43/ 5.1 and MX-Tech had me at a 0.45/5.3. I split the difference and went with a 0.44/ 5.2. A 5.1 spring put me on the short side of the recommended spiring length...and the 5.2 put me right in the middle of the recommended spring length at 100mm of race sag. A 5.3 would be at the high end of the recommended max spring length. The general guideline is the stiffer the better for the rear spring as long as you stay within the recommended spring length range. You definitely didn't go too stiff, I'm pretty sure your as stiff in the rear as you can go which is good.
You might be a little light in the front spring but I would trust factory connection to give you what you need for your riding style. Again, all of the experts have went with what has worked for them by trial and error and the charts are made from their notes. With a 0.43, I would think you would be able to turn better since your weight will sink your front in down a little more than mine. I raised my forks to help me turn a bit better. Racetech seems to set their suspension a bit softer than MX Tech....to me it seems you have an unbalanced (soft) front...I'll leave that up to someone else to confirm or deny if that's true. Your rear spring is fine though.
I'm going to do what factory connection suggest even though it's vary different than i was running here are their click suggestions/ Forks:12 comp- 12 rebound 340cc oil height- Shock:13 LS comp -3 turns HS comp -10 rebound -108mm rider sag /Honda manual Front Compression: 7 clicks- Front Rebound: 10 Clicks -Rear High Speed Damping: 2 turns- Rear Low Speed Damping: 12 clicks -Rear Rebound: 13- 16 clicks /my old settings Front Compression: 8 clicks -Front Rebound: 6 Clicks- Rear High Speed Damping: 1 ¾ turns -Rear Low Speed Damping: 8 clicks -Rear Rebound: 10 clicks as you can see a huge differences
Edited by stkman62
copy and paste i found this on CRFs only
Note: Clicker adjustment should be expressed in clicks from full hard.
Year:
Rider Weight:
Rider Weight with Gear:
Riding Style (i.e. Desert, MX):
Forks Raised in Triples:
Rear Tire Size:
Aftermarket Triples/Offset:
Fork Springs Wt:
Fork Spring Brand:
Fork Oil Amount:
Fork Oil Brand & Weight:
Fork Compression:
Fork Rebound:
Fork Valving:
Shock Spring Wt:
Shock Spring Brand:
Shock Hi speed Compression:
Shock Lo speed Compression:
Shock Rebound:
Shock Valving:
Shock Oil:
Race Sag:
Preload:
Year:2005
Rider Weight: 175
Rider Weight with Gear:195
Riding Style enduro/hare scramble
Forks Raised in Triples: 1/2
Rear Tire Size: 110/90
Fork Springs Wt: .43
Fork Spring Brand: factory connection
Fork Oil Amount: 340 cc
Fork Oil Brand & Weight: 5
Fork Compression: 12
Fork Rebound: 12
Fork Valving: stock
Shock Spring Wt: 5.3
Shock Spring Brand: factory connection
Shock Hi speed Compression: 3 turns
Shock Lo speed Compression: 13
Shock Rebound: 10
Shock Valving: stock
Shock Oil: 5
Race Sag: 108
Preload:
haven't used these yet Factory Connection suggested them the spring are stiffer and the clicks are much softer i did talk to them in detail about my bike , riding style and where i ride i just put my bike back together and now I'm waiting for the 3 feet of snow to melt
Edited by stkman62
This setup works way better for me than stock. Still soft enough for technical woods, yet seldom bottoms in the desert. Rails corners!
I should note that the MotoZ tires made a huge difference!
Year: 2006
Rider Weight: 230
Rider Weight with Gear: ?
Riding Style (i.e. Desert, MX): tight woods, some desert
Forks Raised in Triples: 0mm
Front Tire Size: 80/100 MotoZ Tracula
Rear Tire Size: 110/90 MotoZ Terrapactor S/T
Aftermarket Triples/Offset: stock
Fork Springs Wt: .46kg/mm
Fork Spring Brand: RaceTech
Fork Oil Amount: 345cc
Fork Oil Brand & Weight: Maxima Race
Fork Compression: 16
Fork Rebound: 11
Fork Valving: stock
Shock Spring Wt: 5.6kg/mm
Shock Spring Brand: RaceTech
Shock Hi speed Compression: "-1/4 turn
Shock Lo speed Compression: stock
Shock Rebound: stock
Shock Oil: stock
Free Sag: 15mm
Race Sag: 100mm
Preload: ?
Year:2005
Rider Weight: 175
Fork Rebound: 12
Fork Valving: stock
Shock Rebound: 10
Shock Oil: 5
Race Sag: 108
Preload:
haven't used these yet FC suggested them
I think for your weight, which is about the same as mine, these settings will be harsh unless you ride very aggressively. With the stock valving, I would soften the fork compression 3-4 clicks, soften the shock hi and low compression by about 1/2, and I would use the stock fork springs which are .42 and go to a 5.0 shock spring or at most a 5.2
  • 5 months later...
I just picked up an '06 that's bone stock. I weigh 185 (205 w/gear) so know I'll be going to heavier springs on both ends. But I'd like to know what the spring rates are with the OEM fork and shock springs, so I have a starting point reference. Can you guys tell me what the KG ratings are for the stock springs?
