What exhaust??
you said you're getting the bike friday, right?
how do u know u want a pipe when u havent even ridden the bike?
you need to pinpoint what's wrong with the bike first before spending your money on stuff you dont need.
and primal uses that same argument against every thread closely related to yours...
dont take it as an insult... he's right anyways.
take the $500+ you'd spend on a pipe and dial in your suspension.
:thumbsup:
Suspension? Theirs nothing wrong with the suspension on these bikes bran new! They do have problem with the pipe tho and everyone knoes that. Its the most annoying bike out on the track. It needs a new can if anything.. but that just my opinion.
either invest the money in suspension or if u plan on racing invest in tires air filters levers extra set of bars oils and lubes... that way ur not stuck sitting the rest of the day if something were to break
yea well many people have told me to get a pipe so thats why i was just gonna get one and have that taken care of..for as suspension im not sure yet until i ride the bike.
does it come with a spark arrestor?
yeah it comes with a spark arrestor.
well u must be the true all american man!!!
because the stock suspension does not comply to everyone's body and/or riding experience/preferance.
and what is wrong with the stock pipe? are u saying it's too loud?
Yes its way too loud! I weigh 148 pounds so the stock suspension is perfect for me...
Go to any rough rtrack with stock suspension and then go with dialed in susp..
yeah but you can dial your stock suspension
Yeah i know by revalving it and giving it to somebody who knows what they are doing. It helped me alot.
:bonk:problem with the stock kaw pipes:busted: they have the best stock pipes out there. raced all year with a stock pipe in the 30 and 40b against 450s and won my share of races.
i weigh like 155-160..wud the stock suspension work good for my weight? where are some good places to take it to get it dialed in?
Ok yes the springs will work for you. How ever the valving is generic. Which means it's setup for a ride between 150-160lbs. Lower end riding skill and a mix of riding like trails enduro mx and hairscrambles.
When we suggest having it tuned does t mean springs. It means being valves for your riding ability and type of riding. If you do all sorts of riding have it setup for your the type you ride most.
Do not have it setup for what you think you'll be at ability wise in a year. Example. You just started riding and you know you're gonna be better in a year. Don't have it setup for an intermidiate rider. You need beginner valving. Ride till you are past what the valving supports you and revalve again. If you are a beginner and get intermidiate or pro valving. It will be harsh and hard for you to learn. Plus it can be dangerous.
alrite that sounds good..im an intermediate rider so ill get it set for that. Where is a good place to take it? and how much will it cost?
Price depends on who you go to.
If springs are needed
and if parts need to be replaced.
A full setup with springs from factory connection is in the 800 mark.
With out springs it's less around 4-550.
I would send it to factory connectIon but
Enzo, mxtech, rg3, & others are good.
I personly would not choose racetech unless they are local.
Good luck.
wow thats expensive but ill check it out. thanks for your help.
the springs are good for your weight. i am 160 the stock springs are perfect. i use FC they do great work. you are in cal, so you more choices try looking into mb1 he does great work.
you dont need a full pipe set up, just get a fmf 4.1 slip on, its a spark arrester and it'll make it quiter. You dont need to spend $500 on a pipe. spend it on oils, tires, filters, protective gear, maybe some suspension mods. $500 can go ALONG WAYS if you spend it right..
