Anyone is SoCal want to help me install Hot Cams?
With all the recent threads talking about cam install errors I'm spooked about doing mine. I was hoping to get a set installed and run in before my dual sport ride in late March, but I don't trust any shop to do it. Any of you local-yokels with some knowledge and experience wanna help a brutha out? :ride:
Oh yeah, I'm in Fontana (Inland Empire). :thumbsup:
I would help but I have no experience with the DRZ cam. :thumbsup: good luck
yes ... dont trust just ANY shop
you pay my airfair ... i'll do it for you
Try reading some more threads on cam chain replacement. They seem to have the most information on the subject. I just did mine and have never worked on a bike before I got this one a year ago and found the job fairly easy. If you have done the lock-tite fixes on your bike than you can do this no problem. :thumbsup:
its not that bad at all. If you go to thr hotcams website they have a video its not a drz, but just to get an Idea how its done.
It really is pretty simple to do... Most anyone with some experience and ability can do this task. Read up on it, take lots of dig pictures so you can refer to them later.. and if you get stumped, post up (with pictures) and ask. Check your PM’s
I posted one of the threads asking for help. They are easy to do, it was just that mine did not have any marks to go off of, so we could not be sure. If yours have the marks on them you should have no worries.
I don't remember seeing any timing marks on the intake cam. Don't have the exhaust cam yet, still looking for a good deal on that one. I may just have to go for it, but if I do tackle it on my own I'm going to wait until after my ride in March. Don't want to jack something up and not be able to go.
Boy I wish I could! Weather up here n nor cal sucks right now. I can be there in about 6hours all we need is a babysitter and a twelve pak! If you can't find someone to come over and help maybe the gents that really know the INS and OUTS can post some "do not forget items" to make the job easyier on you. I know there posted in varrious threads but maybe we can make a collective check list of everything that will be needed!!!!
Good luck and cheers., Logan
I just done mine, I'm not trying to scare you off but I did have a slight hiccup on the timing. But a few post/questions later (I pretty much knew) and the problem was resolved, I had a slight timing issue. I "think" the cam chain cap needs to put into place before the MCCT is put into place, not sure here, just thinking. But as a whole, it's no biggie. Heck, you have the best place in the world to ask questions. You SO need to do this before your big ride, as it's only a few hours or so. Then you'll have that silly grin...
If I was closer I would help ya Pauly :thumbsup:.......mines still running :ride:
Thanks Debi! I'd make sure to have a fridge stocked with Negra Modelos if you did!
Same here I'd be more than happy to help but. There are a couple good threads with pictures. Bronco talked me through my adjustment and then when I did mine. I also found this link was pretty good.
Have you got a manual as well for back up?
http://www.pegmonkey.com/howto/valve_adjust/drz400
from what ive seen from you i dont think you will have a issue.
just double check the cam timing before running it.
install them with the tdc line in the hole and the cam marks lined up.install the CCT and rotate the motor 720 degrees till the line is in hole again and look at the cam marks.if they are all still lined up your golded.
no counting pins with hotcams.
I do have a manual. I have the PDF version but would print out the pertaining section(s) and have them in front of me.
Thanks for the vote of confidence, Eddie, I appreciate that.
All right, you guys have convinced me to do it myself. Just need to find a great deal on the exhaust cam. If I don't find a slightly used one in the next couple days I'll suck it up and order new. Found a few on eBay for $125 (new).
And what would you do to help:excuseme:
