06 KX450F Suspension on 05 KX250?
Does anyone know if we can take the forks and shock off of an 06 Kx450f and install them on to an 05 KX250 2 stroke?
get a caliper and measure the forks outside diameter where they clamp on the triple clamps. if they are they same then you can do it. They are both KYB's although I suspect the 06 450's to be bigger by a couple millimeters. But they could be the same. As far as the shock goes, you need to pull them and measure the length eye to eye.
I tried 07 450f forks in a 05 KX250. they didn't fit due to a different upper fork leg diameter. I guess 06 forks are the same diameter as 07, so you have to swap the upper triple clamp too, but I don't know if it fits
I put 07' kx250f forks in an 07' kx450 and like you say the upper clamp had to be changed. I had a set of 07' 250f uppers sitting around so used them.
the 250f has showa forks, don't know the diameter, the 250 2-stroke 56mm upper leg diameter, the 450f 54mm dia.
my 07' 250f had 2mm small diameter at the top clamp than the 07'450f if I remember correctly.
