leaky carb
my carb started leaking out the vent tube maybe i got junk in between the needle and seat what do you guys think
more then likly or worn needle and seat!! pull the carb and clean it but you might as well get a kit make sure the needle and seat come with it !
Float level is incorrect or the float valve is sticking/worn. This causes fuel to either drip or run out the carb bowl overflow tube. Watch out for so called "rebuild kits", most of them are junk. If you need a new float valve, I'd get genuine Keihin parts for it or Mikuni if that's the case.
