dumbfounded by electrical problem 02 520 mxc
So I recently purchased a 2002 520 mxc I have put around 150 miles on it problem free, love the bike. This tuesday i was all geared up and ready i made it about 75 yards from the truck and the bike quit. I pulled it apart and discovered there was no spark. My buddy has the identical bike. I have switched out all his ignition parts with mine to try and rectify the problem, no such luck. I have replaced the cdi, coil, stator, pulse generator, spark plug and wire. Now im lost. The next step in my mind is to start going through every wire in the ignition system looking for bare wires or bad grounds. Any advice will be greatly appreciated. thank you
Does the voltage regulator have anything to do with spark, I understand that the regulator is for the acc. i.e. lights and horn
Probably not it for you, but you should know that there are TWO fuses.
My electric start quit after a crash and it took me forever to figure it out. I saw one good fuse and thought there was only one. But the 2nd had fallen out. Worth checking.
good luck
