Removing oil seals without damage?
is this possible (especially over the top recess area used to seat the DU Bushing at top of inner tube)?
byte
byte
Yes. Just wrap one layer of electrical tape over the edges of the recess, and remove the seals carefully. No hassles. However, I like to put new seals back on rather than re-using what I take off.
SOLD - Thanks for link.
dumb question - will the new oil seal be stretched too far and beyond it's elastic limit as they are placed over these bullets?
Byte
Byte
No. Just make sure you get the right one for your fork size though. Reason I use tape though is that there's always some floating around here, it's dirt cheap, if I lose it all I can pinch some off a neighbour. If I relied on the Motion Pro bullet, then I'd lose it and then wonder what to do and end up using tape anyway! Can also use a sandwich bag over the tube end when putting the new seal on - piece of cake.
Byte
No problem. Nope shouldn't at all. Watch this video on youtube about changing the fork seals. You can see that they use the fork bullet.
thanks
how do i know what position to lock in the new oil seal along the inner tube face?
Byte
The oil seal doesn't lock in position on the inner tube. It slides onto the inner tube and is then driven home into the outside tube. The whole lot is then held in place with a circlip.
